- 3_tonsExplorer IIItoedtows said, “I agree. I think the "too much power for the campground infrastructure" argument is partially flawed.
It is correct in that if a person plugs in BOTH their RV and their EV, they are possibly putting more pull on the infrastructure than most other campers.
However, in that most campground infrastructures are ALREADY underpowered for campers' RV only usage, then the rare EV isn't really doing more than what is already happening on a holiday weekend in 100+ degree temps.
I think we can all agree that campground infrastructures are for the majority not able to handle the load for a campground at full capacity RV usage.
With more and more RVs using residential fridges, multiple ACs, multiple 120v appliances, etc, I doubt an EV only campsite is pulling more power than an RV only campsite. And, as most EVs are only capable of pulling small trailers, you aren't likely to see one campsite pulling power to charge the EV plus run 2+ ACs, 2 televisions, a microwave, coffee maker, hair dryer, electric fireplace heater, electric blanket, etc. “
Really?? I’m sure you’ll have no problem explaining such a uber rational position to an angry neighbor or two who’s suddenly prevented from cooling off their RV - this is where ‘the rational’ gets introduced to the Mr irrational…
3 tons - armed with bear spray - lol - 3_tonsExplorer IIIFeel free to just write me off as a cynic, but my mind can’t undo what I witnessed in the 70’s…Trust that I wouldn’t at all mind bring wrong, but even before the days of Socrates, human nature seems pretty consistent and predictable - I thereby rest my case…
3 tons 3 tons wrote:
Reisender said, “When we charge in a campground we are almost always on a 30 amp site. Our car can’t pull more than 24 amps. Literally can’t trip the breaker. But our little trailer can. Between AC, hot water, fridge, converter, microwave etc etc. Easy to pop the breaker.”
Well, I’m old enough to recall the gas rationing of the 70’s (due to OPEC), snd the long lines at the service stations (even and odd days, etc) and saw more than one uber heated argument (and WORSE!)…Are we to suppose that human nature has by now evolved enough to avert such hostile interpersonal behavior??
3 tons
LOL :). I hear ya. :).- PButler96Explorer
time2roll wrote:
3 tons wrote:
Generally the EV can charge after the sun goes down and the A/C cooling load is reduced. Can we ever just get along?
Another summertime issue in many campgrounds is sure to be that EV charging may preempt the ability of others to operate their air conditioning… As temperatures rise to to 100’s (uh-o :( !!), this is sure to test the mental metal of otherwise friendly fee-paying for services campers…
3 tons - mostly (happily!) :) off-the-grid…
(full disclosure, 400a/hr LFP, 660w rooftop solar - newly added 360w of portable MPPT PV..)
Who generally will enforce such a policy? The charging police? Park Ranger? Buffo the clown? How about the honor system?
There are piles of rules, especially at state and fed campgrounds that go un-enforced. No alcohol and not bringing in outside firewood are two examples, for a whole myriad of reasons not the least is staffing levels. With today's me first mentality, which is inherent to a lot of the EV save the planet greenie crowd, good luck. - wanderingaimlesExplorer
Turtle n Peeps wrote:
Tvov wrote:
Wow... FIVE days to charge on a 120 outlet?? I knew they took awhile, but not that long. Then they switched to the 50amp, and the charging time dropped to 14 hours... yikes, still I did not know they took that long.
For some reason I thought a 120 outlet would be like an overnight charge, not 5 days.
My wife's electric car will charge overnight. But then again it's a PIHB and only has a 30 mile range. I believe it charges around 1.25kwh/hour. In any event she plugs it in when she gets home from work and it's at 100% charge when she gets up to go to work the next morning. This is on a typical 110 circuit.
AND THIS IS EXACTLY WHAT AN EV IS GOOD FOR.
Inner city/urban commuter. Beyond that they are useless to all but a hand full who are willing to mold their lives around charging the car for the next few miles. 3 tons wrote:
When the US went off the gold standard and the value of the dollar dropped relative to other currencies it just made the imports more expensive. Then came gasoline price controls.
3 tons
There was never a shortage. The tankers were lined up at sea to unload and price controls limited what the oil companies were willing to spend. All we had was domestic oil and that was not enough to go around at the time.- wanderingaimlesExplorer
I read this twice and I’m not sure I understand. Why would using an RV pedestal to charge a car pre-empt someone else on another site from running an AC? Maybe I misunderstood this.
For starters, an AC unit for an rv, from that pedestal would hit 18-30 amps for only a few seconds before dropping down to about half those numbers, allowing others to similarly use the power source.
Your EV is a CONSTANT watt sucking plague drawing near the max wattage for every second possible.
Does that accurately describe the EV?
Yes I know the language seems harsh, but this is the root of the issue.
The long continuous draw of the EV charger is the problem. - 3_tonsExplorer III
3 tons
Ok, but without drifting into such root-cause arguments such as Rentier (ron-tee-AA) capitalism versus the historical anomaly (an Overton’s window event) of democratically devised Industrial Capitalism (ending serfdom, making possible private property ownership and the Industrial Revolution) - the 70’s OPEC crisis was just a earlier graphic example whereby the rationing of energy that restricted folks needs, wants and desires, sometimes triggered some awfully bad behavior… That was my only point (though admittedly an ardent fan of world history :) ..)
3 tons - BobboExplorer II
Don't forget that you can have a 45 foot diesel pusher with 3 ACs and a clothes dryer towing an EV that needs charging. - 3_tonsExplorer IIIMaybe the real question is, when the heat wave hits, should CG pedestals be repurposed for charging EV’s??… Like it or not this will surely be the position of some affected others…Just saying…
3 tons
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
