- pianotunaNomad III
wanderingaimlessly wrote:
Would have been nice to know if they found the issue. I use a Hughes Power Watchdog, which scans the post, something like that here would have been helpful.
The issue is the four pin plug is for 240 volts. The 30 to 50 adapter does 120 on each leg so it will not work. One could make an adapter tht would work.
A way to test would to be to use the 20 vehicle plug, with a 30 to 20 adapter. That would present the correct voltage to the charging adapter. - toedtoesExplorer III
BB_TX wrote:
toedtoes wrote:
The 20a outlet looked like it was scorched and the 30a outlet did also. I wouldn't have hooked up my RV or vehicle to that pedestal without checking it out first.
Actually it looked like most of the older campgrounds and RV parks I have been to.
I'd be testing them too. - wanderingaimlesExplorerWould have been nice to know if they found the issue. I use a Hughes Power Watchdog, which scans the post, something like that here would have been helpful.
- rhagfoExplorer IIIUsing the 30 amp to 50 amp likely confused the charging unit as both legs of the power were on the same phase. Well 15 hours to full charge from 22%.
- BB_TXNomad
Actually it looked like most of the older campgrounds and RV parks I have been to. - Y-GuyModeratorMoved from Tech Issues to General RVing Issues
- toedtoesExplorer IIIThe 20a outlet looked like it was scorched and the 30a outlet did also. I wouldn't have hooked up my RV or vehicle to that pedestal without checking it out first.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 05, 2026
