MegB wrote:
I appreciate all the advice,however I really just want to know about getting a battery charger....not about all the other things I could do instead. I don't have the knowledge to install things nor do I want to pay the big bucks to have it done for me. Just was curious about the charger versus running it at stops. Does anyone know anyone who uses a charger???
I know you asked about a charger but that means installing something too. IMHO do some research or post on 'which fuse to pull' for your model car.
THAT would be a 'real' easy thing for you to do to rectify the problem.
Also check that your radio is off, heat and A/C fan off, courtesy light off AND your auto headlight switch is turned to manual. You might be draining more if any of these items are on.
