urbex
Apr 13, 2016Explorer
RoyB wrote:
The typical Truck Alternator setup was only typically designed to charge up the ONE Truck Start battery.
My understanding has always been that the alternator is there to maintain a state of charge, not recharge a low battery. This is an important distinction, as the alternator doesn't have the circuitry in it to properly charge a deeply discharged battery. Sure, driving around for a while will eventually "fill" the battery back up, but it doesn't do it in a way that maximises battery life.
The intentions of the high amp alternators, and dual alternator setups is for vehicles that have higher than normal electrical loads, such as emergency vehicles with a bunch of added lights. electric hydraulic pumps, bigger cooling fans, etc.
It's always been my understanding that the 12V charge line was intended for maintaining small batteries, such as those that power the breakaway system on trailers, not charging up the house battery (or batteries). Even then, you're supposed to charge the brake system battery to full with a battery charger, then the TV maintains that charge.
https://www.optimabatteries.com/en-us/experience/power-source/fact-alternators-are-not-designed-to-charge-dead-batteries/
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: Oct 05, 2015
