RoyF's avatar
RoyF
Check those lug nuts
If you haven't checked those lug nuts on your trailer or motorhome lately, then better do it before that first spring trip.
I got my fifth wheel out of storage yesterday and parked it in front of my house to prepare for a trip leaving tomorrow. This morning, I noticed a lug nut in the street about 30 feet from the fiver. Who could that belong to? Well, it was mine!! One nut had dropped off right there in front of my house after a five mile trip from the storage site. Several other nuts were slightly loose and needed to be torqued.
I should check lugs before every trip, but I have to plead guilty.
  • I use a red paint pen after torquing the wheels and mark their position. I have white steel wheels so red is easy to see. I also do a hand tight check before each trip.. Seems to be working for me....
  • I don't check lug nuts on a regular basis, bit I never had a loose one when I did check
  • And don't forget your toad/daily drive/TV.
    DW said the Jeep was handling poorly at slow speed. Went out and found one wheel only had two lug nuts. Studs were gone or broke.
  • And check the nuts on your U bolts on your axles also. And just about every other bolt/nut/screw on the rig at the start of a new season.
    Only 3 of my 32 lug nuts needed any tightening at all. And then less than 1/4 turn.
    But over half of the nuts on my U bolts needed retorqueing.
  • We had bought a 2011 Keystone travel trailer (have since upgraded to a coach) and the manual had very specific torque instructions... like a two stage approach. But it also said to torque before every trip. These were aluminum rims, if it matters.
  • We check the torque on the lug nuts and the tire pressure each time we tow our 5th wheel. Some might consider this overkill . It only takes a couple of minutes and has become part of our pre-departure check list.
  • Sounds like that storage yard may not be very secure if people are messing with lugnuts.
  • I learned that the *real* hard way by losing a wheel. Imagine looking in the side mirror and thinking "wow.. poor guy.. lost a wheel"
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 13, 2026
