dwayneb236's avatar
dwayneb236
Check your electric BEFORE unhooking
This past week we were in Oklahoma camping at Foss Lake State Park. Pulled into our spot and began doing our thing with unloading and such. I have installed a PI EMS-LCHW50 in the unit so I wasn't worried about any electric issues as I was protected. What I forgot to do first though was check for any error codes. I just plugged in and began doing other things.
After all done, I went in to turn on air for the dogs. Well the thermostat was throwing up an error code and wouldn't turn on. I finally got a brain and went to check my PI readout and it said I had an E2 code. This was an open ground and the PI shutdown so I wouldn't do any damage.
Was glad for it and did learn me a lesson. Check electric before unhooking and leveling and running out slides and all that other good stuff.
We loaded back up and moved next door, checking electric before doing anything else.
Don't know what this could have done to our system without the PI but nice to have it and not worry about it.
  • bpounds wrote:
    snip
    Flip side of that coin is, that an open ground on the pedestal would not have harmed your rig, and your AC would have worked fine. Just as if you were on a generator. Your rig does not need a ground, just a hot and a neutral. The ground prevents someone getting shocked at the pedestal.
    Yeah I know nothing about electricity so I just didn't want to take any chances. Now I know but I would still have moved as the EMS wouldn't allow me to use the air unless I bypassed it and that would just leave me open to surges and all that other nasty stuff I don't understand at all and am probably wrong about most of it.
  • DW edicts that getting the air conditioner on pronto is priority one, so checking the pedestal is the first thing I do. My power cord is long enough that I can do some minor leveling while plugged in.
    And that is even though I have a PI EMS-HW30C.
  • dwayneb236 wrote:
    bpounds wrote:
    snip
    Bottom line----believe your EMS. Without a ground, if there is any stray voltage, it may energize all the steel and aluminum in the trailer. This is especially bad for pets as a dog or cat has much more vulnerability for electrocution. Old Fido may step on the steel entry steps and that may be his last step.
  • Well the slides actually weren't out yet but I was in the process of leveling as I had just unhitched and level before the slides are out. The wife takes care of stuff on the other side of the camper and told me the ac would not come on so I went to investigate. Did have the sewer and water connected as well. The spot we moved was right next door so no repacking to do, just hitch and go. Still annoying.
  • Even though I have a hard wired PI EMS HW 30 I always check with my home made pedestal checker,cheap but it works.
    Saves me the hassel of dragging everything out.
    I also use my 50amp to 30amp adapter to check the 50amp side. Sometimes I like them better as the are in better shape.
  • I always use my Power Pal before I start to unpack anything, first thing I do is plug it in and listen to it tell me everything is fine, or not. Power Pal
  • Old-Biscuit wrote:
    Except that 'open ground' at power pedestal could result in a 'hot skin' condition on RV. That can be very dangerous to the RVr
    Absolutely. In fact, it can be deadly and has killed in the past.
    Our PI EMS showed we had an open ground at a CG last year and I notified the office. They sent over their general purpose handyman/electrician who used his voltmeter and declared it perfectly fine and that it should be fine because he had just replaced the receptacle (30 amps) a few days ago. I have a serious problem with non-electricians working on CG wiring but it happens all over. The next time it happens, I might write to the state chief electrical inspector.
  • Oh yeah, Just an FYI I did report it to a campground worker. He said he'd contact his boss about it. He was a nice enough guy but seemed a bit confused when I said it was an open ground. But I was confused too so we had something in common.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
