SkiingSixPack
Jun 27, 2015Explorer
Just fill the empty spaces with frozen gallon milk jugs (washed out and 75% full of tap water). A full freezer and no opening of the lid, is the way to go. With 4 teenagers, I don't need to do this any longer, but I used to...Our freezer is full of food ..... :-)
This is from thesimpledollar.com
"Fill your empty milk or juice jugs with water, then stick ‘em in the freezer.
A freezer, whether it’s a deep freezer or a freezer housed in the same appliance as a refrigerator, functions best when it’s really full, as the cold items help keep other items cold and maintain the low temperature.
But how can you keep it full without stocking it with a bunch of food that you may or may not eat? If you’re not into filling your freezer with food, fill it with water.
It’s simple. Take an empty milk jug (or juice jug), rinse it out, then fill it about 75% full with tap water. Stick that jug in the freezer and just leave it there. It’ll freeze, then it will help keep the temperature of your freezer low over the long haul, causing your freezer to kick on a bit less often to keep your items cool.
Even better, you can directly use these jugs when you need a lot of ice. You can either stick the jug entirely in a cooler or smash it open and use the broken ice pieces to your desire. Works like a charm – we do it all the time!"
Looking for advice before your next adventure? Look no further.25,189 PostsLatest Activity: Mar 27, 2026
