kohldad
May 20, 2014Explorer III
I am going to be solo camping mostly in places that have no paved roads
Just to add some confusion to your hunt, how far from the paved road do you plan on going?
The negative to Class C or B+ is the large rear overhang and rack of ground clearance. Wouldn't take much of a stream crossing or water diverter to hang up a motorhome.
Have you looked into a Truck Camper? Much better suited for going off the beaton path. Some have slides if you feel you need the room.
In other regards to your original question, a C or B+ will basically get the same MPG. While there is a bit of difference in aerodynamics, not enough to make a difference. Biggest issue is the weight is almost always right up there at max for the vehicle.
Looking for advice before your next adventure? Look no further.25,205 PostsLatest Activity: Aug 17, 2026
