Guysakar's avatar
Guysakar
Class B vs. Class C, of same length?
Preface: I am not talking about class B vans, but the larger class B. I have included an image of the type I am looking at. Not this exact model, though. Just a reference.
Hi guys, I am planning on mostly going to campsites off the beaten path and am looking at shorter units (22-26 feet) for around $25K.
I am seeing both class C and class B's in this price and length range.
I like the way the class B's look (more sturdy/compact) but the class C's seem to be cheaper $. Plus, the above cab space seems to be wasted in the class B, but does that translate into more MPG (aerodynamics of the wind deflector)?
I am going to be solo camping mostly in places that have no paved roads, and am looking for units with a slide. I will be towing a small trailer and motorcycle, occasionally in the mountains.
Gas mileage is an important factor to me, but overall reliability and maintenance issues are paramount (does one type tend to leak more, need to be sealed more often, etc...)
Do you think I would be happier with a C or B, or equally happier with either?
Side note: I know, condition, etc... is a more important factor, but all of those factors being equal.
Thank you all very much for any help.
  • Your pic is _not_ of a class B. It's just a small C with no overcab bunk. A B is a van.
    Jim, "My mom told me I could be anyone I wanted to be. Today, that's called 'identity theft.'"
  • What you've pictured is a C. Gulfstream started marketing this as a B+, others picked up the term.
    It is a C without an overhead bed. Some models are narrower than the widest of C's with the overhead, but those vary in width. Some models are a little lower than C's with basements, but about the same height as C's without basements (e.g. the LazyDaze and many rental models are built low).
    A B is built within a van's body, sometimes with width extension. The C/B+ are built as a box on a cab-chassis or cutaway chassis, usually at least seven feet wide and nine feet high (sometimes up to 12 high). It has a whole lot more room inside.
  • Had a 20' Pleasure Way, no slide. Pro... easy to manuver, fit and finish excellent, well planned out inside. Now have a 26' Winnebago Aspect w/one slide.. pro..
    larger gray/black tanks, little higher clearance, fit/finish nice, basically looks like your picture. More storage, larger refrig. Gas mileage on PW was about 12 mpg, Aspect about 10 mpg. Aspect actually holds the road better.
    Just my 2 cents worth.
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 27, 2025
