PA12DRVR
Sep 17, 2021Explorer
"Interesting comments. I surf other forums and dielectric grease was always recommended as the solution for this problem. I can tell you only from my experience, since using the grease, I have this error less than I did using a dry connection. I will continue to use it even if it is the wrong product, only because it works. Thanks for the definitions and experience from electricians and electronic techs."
My experience as well. The emery board, sandpaper, etc probably helped, but after doing that AND applying the dielectric grease, the repeated "trailer disconnected / trailer connected" cycle went away and has been gone for 2+ years now vs. the usual 1-2 weeks after using ONLY the emery board / sandpaper / wire file solution.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
