JRscooby
Sep 17, 2021Explorer II
Gdetrailer wrote:JRscooby wrote:
I'm not much smarter than a box of rocks, but have used Dielectric grease on hundreds of light cords for millions of miles for decades. And sense I started, the only issue I have had is careless handling. Start with tight, clean connections. A little of the grease about every 10-20 unhooks. I assume that like any grease, it will keep moisture, therefore corrosion off the contacts. And because it is non-conductive, I do not need to worry about it causing short circuits.
In the case that is "working" for you, basically you are depending on the contact springs to be strong enough to displace enough of the dielectric grease from the contact surface to make a electrical connection.
Sometimes works, sometimes doesn't.
The metal to metal contact is all that will carry the current, even if nothing is used. And the odds the friction of connecting will scrape off the grease is much higher than it will remove enough of any corrosion
Whatever contact is being made is compromised electrically and adding needless resistance to the equation.
Any corrosion will also compromise the contact. And it will also reduce the spring pressure. Cleaning likely will restore contact, but every time a abrasive is used, there is less metal, weaker contact.
The proper tool is two of the greases I mentioned (Oxgard or No-Alox) and you just apply that to the contact surfaces only, it will not run or creep and it is specifically made for doing the exact thing you want which is to keep moisture away from the contact surfaces.
There is 2 things that can go wrong when you plug in the light cord. Bad contact, and just as bad if not worse, contact between the conductors, or a short.
When mine is covered with dielectric grease, I plug in, the contacts slide on each other, the grease will stack up in bottom of socket. I would be willing to bet the magic you recommend will do the same thing. But, and to me a big but, the dielectric, being non-conductive, will not cause a short.
I would add that your recommendation would likely reduce problems in something like a crimp connection, where the fit tightens after the wire is in place.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
