dee74's avatar
dee74
Cleaning top of slide at campground
My new tt has a slide and this is new for me. The dealer said it was important to clean the slide off before closing it at the campground. What are some easy ways that you clean your slide. I know I could pack a ladder and a broom but I would like to avoid dragging a ladder with me everytime I go camping.
  • It only makes sense to brush or blow off the slide before retracting it. As stated above, sticks and twigs, (anything) could tear the rubber roof, or poke the rubber seals around the slide. And as someone else said, when they don't clean it off, they get leaves and such 'inside' the camper! (and then some folks wonder why their slides leak around the seals, hum????)
    I keep a ladder and a broom available all the time so I can brush all 3 of my slides off before retracting. Pain in the neck? Maybe? But a ripped roof or punctured seals is a bigger pain in the neck AND the pocketbook!
    I brush until it's 100% free of everything. I use a painters pole (a long one that collapses with a soft fluffy RV brush). I keep a 6 foot step ladder in the bed of the truck. And every time the slides are retracted, I brush them off first. Also, while I have the brush, I usually run it in the gutter track. It bunches up with small droppings from trees real fast. This has just become part of the camp tear down procedure. I've spent too much on my camper to simply disregard something so simple to do and could result in such an expensive repair. Whenever parked under trees, you are taking a risk if you don't clean it off.
    An easier way? I haven't found one yet, and I'm the guy that's always looking for the easiest solution.
    Last week-end we were parked near a tree. I dropped all kinds of small stuff on the camper, truck, all around and we were not even directly under the tree. The little green seed pods (or whatever they were), were real sticky. They clung to everything. I had to really work to get them off the dog! And the awning and the slides. But I did and the dog is much happier now too! (and so am I).
    do your slides have slide toppers...a fabric covering that rolls out and in with the slide? if so you won't need to clean the tops as the topper will keep 99% of the crud of the slide. if not then consider adding them.
  • After purchasing first trailer with slideout, I decided that a slide toper was the answer. Other than that, ladder and broom or a blower is the answer. Slide topper also avoids problems with water on top of the slideout. Downside of slide toppers is that you can get some noise in strong winds and possible pooling of water. For pooling of water, I simply bring in the slideout slowly and allow water to run off.
  • If you camp where trees are over your rig then you should clean it off because STICKS and TWIGS can rip the roofing material when bringing it in. I was in a GC under pine trees and it dropped so many cones and twigs it would have been total destruction if it had not been cleaned off. I have a ladder on the back of my TT so its not an issue getting up there.
  • Community Alumni's avatar
    Community Alumni
    I use a cordless Black & Decker leaf blower, works really well.
  • Had a slide in the last TT with no slide topper and never cleaned it off for 8 years, I did wash it every couple years. We got some leaves inside a few times when closing but that's it. We do have toppers on the slides now.
  • In August, I will have had my trailer 3 years. Dealer had likely told me something similar. Initially I was worried about it, brought step ladder and push broom, rarely got much off. Since then, have been out in it every month since purchase, now only look at top twice a year when I'm on top cleaning and inspecting roof of trailer. Don't know if lucky, or reality is that not much collects there.
    Your experience may vary!
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 27, 2025
