Dave_H_M
May 14, 2014Explorer II
mhsmith wrote:
I agree with Gdetrailer as far as the pads most likely being stuck. At some point(you added the trailer) and the brake problem became coincidence. The pads were "stuck" and unable to release properly and wore down to where they are not a problem right now. Most likely the pads and pad hardware need to be removed, mounts cleaned of rust and I also like to put a dab of silicone under the hardware to slow down the rust build up.
Agreed. If it were mine the brake components on that wheel would get knocked apart and be closely looked at. If I could not find anything suspicious I would then "throw" a brake hose at upon reassembly.
With my luck that would not change a darn thing. :R
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
