relaxin's avatar
relaxin
cold burst of water
Has anyone found a cure for that cold burst of water that occurs when you have the shower head turned off while soaping or shampooing, and a minute later turn back on what was a perfect temperature to get that ice cold shot of water for 5 or 6 seconds till the warm water comes back up the hose.
I am thinking a check valve in the hot line but it baffles me that the hot line would actually back flow as the tank is on and heating therefore causing expansion.
Has anyone solved this minor yet annoying inconvenience?
I don't think its my unit as I had the same in the previous rv as well
  • Yes. When I turn it back on, I aim it at the shower wall for about 5 seconds, then turn it back toward me.
    Cheap and easy fix.
    (Yes, I realize this is a sarcastic response, but I found that it does work and it was really cheap.)
