rockhillmanor
Aug 11, 2014Explorer II
dcason wrote:
We had mice visitors while traveling in our class during last fall in the Wild West and recently while parked in our driveway (both easily dispatched by spring traps).
What are common entry points?Hubby did a quick look under and he didn't spy any spots.
I am thinking he doesn't know what he is looking for...lol!
So shortly we are both crawling under to have a look...any suggestions? This is a class C. We want to grab some spray foam, some steel wool and seal them up tight or eternabond scraps/double sided.
Donna
Go out at night and turn on the lights inside your MH.
THEN crawl underneath and hang on to your hat when you see just how MANY openings where the light shines thru there are.
Each and every hole the manufacturer has to drill for water pipes, electrical etc are drilled larger than needed and NEVER filled in. :C
Pick up a can of GREAT STUFF light expansion to fill holes.
http://www.homedepot.com/p/GREAT-STUFF-16-oz-Gaps-and-Cracks-Insulating-Foam-Sealant-162848/100003351
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 10, 2026
