ScottG
Apr 15, 2018Nomad
GordonThree wrote:
AC current is neat, you can trade voltage for current and vice versa, using simple magnetic coils.
Boosting 100 volts to 120 volts, with wattage remaining fixed (same load), means your transformer will drawing more amps over an already overloaded distribution system to make up the volts.
I can see a park with a sub-standard system being upset about blowing a main transformer or damaging lines if everyone were running their own transformer.
It will make the problem worse for others on the system that don't have their own transformer. Your transformer will only cause the voltage to drop even lower for others.
Given today's society, the me-first thinking that's popular, lowering someone else's voltage is not my problem, others can buy a transformer too of course.
Report this park to the County building inspector, and the state building inspector. Low voltage is a safety issue.
Right on the mark.
An autoformer is not ever going to cause problems for the USER. It only creates more of a low voltage issue for others.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
