ScottG
Apr 15, 2018Nomad
Lantley wrote:
P=I*E Power = current x volts
Lets use a 30 amp circuit operating properly
P= I x E 3600 =30 x 120
However under low voltage conditions
there is only 100 volts instead of 120
P= I x E or 30 x 100 =3000
the autoformer takes that same 3000 watts
and keeps the voltage consistent but the available current drops
3000 = 25 x 120 .(note current dropped from 30 amps to 25 amps).
Power is still 3000 watts
Now there are some heat losses and losses do to impedance. But over all that is the fundamental function of the autoformer.
It ensures adequate voltage, however in the process less current is available.
On a 50 amp circuit we don't necessarily need the full 6000 watts.
50 amps x 120 volts=6000 watts
So if the current drops a bit it doesn't matter as long as adequate voltage is maintained.
What??
The voltage stays consistent through the autoformer?
Maybe you meant wattage? You'd still be wrong.
Some heat losses due to impedance?
Impedance has nothing to do with it. The heat comes from flux generation.
Current doesn't drop in the autoformer, it goes UP as it raises the voltage.
There's much wrong with your understanding of electricity.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
