SoundGuy
Apr 18, 2018Explorer
valhalla360 wrote:
Also, where is you surge guard mounted? If it's at the pedestal, you can easily have 50-60' of line with further voltage drop. Even the built in ones an have another 20' from the device to the air/con unit.
You must be confusing me with someone else as I never said I'm running a TRC Surge Guard. :R Several years ago I did have an early version portable TRC Surge Guard hard wired into the trailer just before the converter but replaced it with a hard wire Progressive EMS-HW30C which sits under the sofa and is likewise wired into the main service line that runs back to the converter. Like others I've found Progressive's meter calibration lacking and have re-calibrated mine so it does indeed disconnect at an indicated 104 vac. :B
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
