myredracer wrote:
When an autoformer is in boost mode, you lose available capacity compared to being at 120 volts.
Although I may be plugged into a 30 amp campsite supply my normal draw is but a few amps, enough to keep the fridge running, the converter idling, etc, and it's only when we may briefly run the toaster or coffee maker would that draw increase ... but only for a few minutes and still only adding ~ 6 amps to the draw. Only those few times each season we may run the A/C for a few hours would we draw an additional 14 amps but in those cases, because we always practice power management and would turn off the A/C compressor for a few minutes while using another high draw device such as my wife's hair dryer or the toaster or coffee maker, our total draw is always still within 20 amps max. I can't think of
any time we've pulled more than that so any loss in capacity due to autoformer use would be a moot point for us ... and moot for anyone else who gives this any thought. :R
myredracer wrote:
If you had to, I would argue with a CG that if the voltage is low, you draw less power compared to being at the normal 120 volt level so what's the problem... Have fun with that.
Too funny. :B You just made me spit out my tea. :W
myredracer wrote:
In reality though, I don't think there are really that many autoformers being used. I've only ever seen a small handful of them in our travels.
A "handful" I'd bet would even be an overestimation, more like hardly any at all.
myredracer wrote:
Have also heard of some CGs banning electric heaters which I don't understand because they don't restrict the use of AC units.
I've never seen this here in Ontario but we have run into several campgrounds in the US where we've been advised when checking in to let them know if we intend to use either an electric heater or A/C and pay an additional fee for doing so. :(
