ryoung
Sep 30, 2016Explorer
OP wrote:
Thanks for asking , each appliance has its own regulator, my hoses will be before the regulator on the motorhome.
For safety's sake, I would run any hoses from the low side of the tank regulator and NOT from the high pressure side of the tank. Depending on the ambient temperature the tank pressure can get as high as 160 psig and maye higher. A hose failure could be disastrous at this pressure.
The low side of the regulator is usually set to 13" Water Column, which is less than 0.5 psi., a much safer pressure. You will have to remove any regulators hooked to the inlets of the lantern and BBQ grill. Do it the safe way.
ryoung
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
