SheDrives's avatar
SheDrives
Connections, dumping, and disabilities
I've read through lots of posts having to do with modifications to RVs to provide access for those with a disability, but no one has discussed the issues that concern us. Hubby is a hemi-plegic (paralyzed on one side) with no use of his arm or hand on the paralyzed side. We are buying a travel trailer and have been narrowing the list to those where he can safely get in and out and where the bathroom and sleeping areas are suitable. (You wouldn't believe how MANY trailers we've had to rule out!)
What I haven't seen discussed anywhere is how to handle the connections at the site and at a dumping station. While I certainly can take care of these chores, Hubby will want to be as independent as possible. Are there any gadgets (modifications, tricks) which can make it easier to perform these tasks?
Thanks in advance,
Elsi
  • I'd suggest that you use the onboard fresh water tank. Its much easier on most RVs to fill that tank than connect and unconnect to city water. Electric shouldn't be difficult. Twisting the sewer hose off and on will be the issue I believe. Mine's tight!
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 27, 2025
