Glowrdr's avatar
Glowrdr
Considering a generator purchase - need advice
So, I've been contemplating getting a generator for my travel trailer (and just to have for convenience otherwise). I'm kind of torn between a couple of models, but a sale has prompted me to consider buying one (or two) today.
I know Honda is the cats meow, but I can't handle the price for my needs. If I was a full-timer, then it might be different. My buying a generator is probably a waste anyways, as I might only use it a couple times a year (but then again, maybe I'll use it all the time once I have one?)
Doing my research, I have put the Champion 3100/2800 watt w/ remote start on my short list. I like the idea of remote start, and feel this should be a decent size to run a 13.5k AC unit. This is the minimum requirement I'd have - no sense in getting a unit that can't run the AC in my book. Here it is for $900 on Amazon
But, I can get a Wen 2000/1600 (or 2) and run in series. There may be some benefit to having separate units in case I know I won't need AC - then I can just take 1 with. They would also provide more power when paralleled. Normally, they are $489 on Amazon. But I can pick them up for $380 today only. Wondering if this is a good enough deal to jump on? Do I pick one up at least, and get a second if I need it, or do I just grab 2 right away? Essentially I can have 4000/3200 power with the connect cables for $810. Here is the smaller Wen unit on Amazon
So what would you do? Go with a larger, single unit option? Or get the 2 smaller units and bridge them? I have no personal experience, so that's why I'm here asking. Thanks!
