n0arp
Aug 28, 2016Explorer
For your case, go with the two smaller ones. You'll get more power out of them and they are easier to handle. You can take only one if A/C isn't required. Not sure about Wen, but check out the Champion units of the same size as well.
Since you are only running them a couple times a year, make sure to get all of the fuel out of them and that the carbs are dry between uses so they don't gum up. Or at least use something like Stabil and run them once a month for half an hour.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
