gypsmjim
Oct 06, 2014Explorer
Converter and Battery Charging Issues
We have had the 195RB for 2 months now. It is permanently set up on our own private camping property and my only source of power is a Yami inverter generator. Everything has worked flawlessly. However, when I first fired up the generator and checked the voltage I found the battery was not charging. When I wiggled the fuse the fan in the converter started up and it went to 13.5 volts. Since then, same thing. Out of 10 times, 8 times i have to wiggle the fuse to start the charging.
Comments...advice?
Comments...advice?
