- Thunder_MountaiExplorer IIDoes your 2011 have a factory towing package? If it does, you have to make a secondary connection. Check the instructions. Our 2012 Rubi came with the factory towing package. As a part of the deal the dealer had to pull the Cooltech from the old Jeep and install on the '12. Took them three tries to make the left light work.
- jhladyExplorerFreightguy,
I have a 2009 JKU and had the same problem. I fixed it by playing with the connections from the CoolTech wires coming from the front of the Jeep to the light connections. Somehow had them hooked up wrong and it was by-passing the left hand lights. Works now.
Hope this helps. - Dog_FolksExplorer IICheck the ground carefully.
Bad ground is the most common problem with all items being towed.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
