In that link it shows a poly crystaline panel. That is the lesser compared to the mono. The poly uses chips (think OSB wood) instead of a whole piece of silicone solar stuff (think ply-wood). It is a slight difference.
That panel is 4 squares across and 8 down. You can see two lines going vertical through each square. You are better to get a higher quality panel that will have 3 or 4 (or 5?) of these lines going through. They are more efficient.
IDK what that charge controller is . If you plan to get a charger controller then get a MPPT. The PWMs are good, but not as good. The MPPT will do a better job and use more "stages" to charge and float the battery.
Avoid the $18 ones, they might not even be real MPPTs. The chinese lie so much now about any and everything to sell you their junk it is not even funny. There is good stuff and there is bad stuff made in china.
