lanerd
Mar 04, 2014Explorer II
therink wrote:
Weigh your truck as if loaded for camping. Subtract the scale weight from your 7100 payload. The difference will be how much hitch weight you can safely accomodate.
Not quite.... should read:
Weigh your truck as if loaded from camping. Subtract the scale weight from your GVWR. The difference will be how much PAYLOAD you can safely accommodate.
For the OP... tow ratings are a sales gimmick. You're main concern with the Tahoe will be it's "payload" rating.....as you will max this out long before you max out the tow rating.
Keep in mind, the "payload limit" will include any and every thing you put in or on the Tahoe....all occupants, equipment, tools, misc gear...AND the tongue weight (including the WD hitch) of the trailer.
Hope this helps..
Ron
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
