turbojimmy's avatar
turbojimmy
Couple of Inverter Questions
I'm headed out to NASCAR tomorrow morning, which means 2 1/2 days of dry camping. Last year the fridge quit working on propane (okay, I broke it) so I had to run the generator 24x7 to keep the fridge on. After less than 12 hours, however, the genny quit too.
I got everything fixed and working again, but in the meantime I also bought a 2,000 watt inverter. I figure I can run small stuff (boom box, phone chargers, etc.) on it without running the 6,500 watt generator.
I get a pretty big arc at the battery when I first connect it. I've read this is normal. My first question is whether there's any draw from the inverter if nothing is plugged into it (other than the little green LED light)?
Second, and this is more of an observation, I have one of those extension cords with multiple receptacles, each with a little LED light. When plugged into the inverter, the lights don't light up but I still have power. Interesting.
Third, and this might be more hypothetical, if I were need to switch the fridge to 120V how long could I keep it on before recharging the batteries? It has a 300W heating element (2.5 amp draw) and I have 2 12V deep-cycle batteries (3 if you count the chassis battery, but it's isolated so I do have a backup). They're in good shape and fully charged (or will be after the drive there). I can keep an eye on the battery monitor, but I need a ball park - minutes, hours, days....
  • There is no specific answer available on your question, but if this helps consider,,,,
    2 12 volt batteries likely 85 Amp hr each so 170 total.
    You shouldnt let batteries go below 50% charge so 85 available.
    2.5 amp hr use for fridge,
    So possible 34 hrs use for fridge alone,,,, but
    You then mention the additional uses of boom box, phone chargers, I assume lights, water pump, TV and the booster, and all the small phantom loads.
    So you make the call as to how much to shorten your time from the 34 hrs, nobody else can really tell you, but yeah, after day 1 you will have to run the genny a few hours a day at best.
Looking for advice before your next adventure? Look no further.25,125 PostsLatest Activity: Oct 02, 2016
