riven1950's avatar
riven1950
crimping battery lug
Ok, this is on my boat but very well could be an RV question so I hope it is appropriate.
While replacing a pump I noticed one of the positive battery cables going into the battery selector switch appears loose in the lug.
Problem is there is very little room to work and removing the entire cable is a lot of work.
Trying to figure out what hand tool I could use to press the lug back on the cable tightly.
I looked online and see people using a hammer and screwdriver and some sort of press. I don't have a crimping press and not sure it would fir in the small area I am working. I have a hammer and screwdriver but not very helpful where I'm working either.
Any ideas?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    byronlj wrote:
    Take the lug off, clean it, and solder it back on using flux.
    Sounds easy.. But do you have any idea how big a soldering iron you need to handle Battery cable (4ga or bigger) wire.
    A welding torch would be my first choice.. Though I might do it with a good propane torch.
    The crimping tool someone up-thread suggested.. From the photos it looks like it does a very professional job. Some of those hand tools I use (on smaller wires) the crimp looks to my practiced eye to be better than some factory crimps.
    That is one of 'em.
  • Take the lug off, clean it, and solder it back on using flux.
  • You can buy another cable with double lugs for about $10 on Amazon. How hard can it be to take the nut off the battery and the nut off the back of the perko switch?
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Nov 25, 2025
