jhlee's avatar
jhlee
curb side tire run hotter
I have a 5th wheel and according to the Tire Pressure and temperature gauge the curb side tires run hotter than the street side. I have Goodyear g614 and filled the tires to 95 psi this morning. around 2 pm the air temp was 86. curb side front 104, curb side rear 104. Street side front 91, street side back 93. I was traveling north bound. The wheels and hubs feel a little cooler than the tread by touch of the hand. 3 weeks ago I had a blow out on the curb side rear but I have noticed for the past year after I purchased the TPM that the curb side tires always run about 10 - 12 deg warmer and the rear curb side tire is usually 2 - 3 deg warmer than the curb front tire. When I put on the spare tire I did check that the wheel turns freely. The RV weighs 12.1 on the scales GVRW is 16k. 2006 KZ 37K toy hauler with no "toys" in the back. Tires are not wearing abnormally. Any suggestions?
  • Our curb side is 900 pounds heavier than the street side. We run our G614 at a 110 psi. On our last set of tires we had some bad wear at 95, so now I run 110 psi.
  • I have not seen scales side to side but I will check around. This rig has three slides but two are on the street side. Thanks for your suggestion.
  • My guess there is mpre weight on curb side. Get it weighed side to side to verify.
