SidecarFlip's avatar
SidecarFlip
Explorer III
Aug 25, 2017
CW employee
Was discussing RV's with a friend's son who works at a CW in South Carolina and we were taking about RV's in general with no particular brand discussed...
He told me that quite a few units come in on trade that have water intrusion issue because owners never maintain seals. He told me that most of them go to thr wholesaler because of the cost to remediate and a good percentage of those are beyond repair and eventually get scrapped.
We discussed some easy ways to determine water intrusion without actually removing things like carpet. I showed him my trick, if you will, of using a non-contact IR thermometer to inspect the interior walls and note the temperature differential (usually 3-4 degrees) between areas with water intrusion and dry walls. Rotting frames and water logged insulation grow mold in dark enclosed spaces and the mold generates heat and an IR thermometer will show that, much like a thermal imaging camera will but at a lower cost.
We also discussed the current lack of quality in all RV's. He told me he sees numerous obvious defects in newly delivered units and they are swamped with warranty issues, hence long waits for issues to be addressed.
He said there is an acute lack of qualified RV techs, asked me if I was interested in working at a local CW in as much as I'm pretty well versed in not only finding issues but repairing them. I passed, I'm retired.
We also discussed the CW affiliated Seal Tite System where an RV has a positive pressure applied to it and seal failure can be determined. I strongly recommend it at least yearly.
  • Neat idea. Wonder if a 3-4 degree swing is enough to really tell though, depending on how much sun has hit one part of the wall vs another. I'll have to try it sometime and see.
    Mike
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Good idea Sidecar, and keep your good posts coming; I've enjoyed them and learned from them.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
