Caryite
Jul 07, 2013Explorer
JEBar wrote:
installed a Cyclone on our camper back in '06, it has performed as advertised .... you might be able to seal the joint shown in the picture but it is an invitation to leak .... could you find an adapter that will fit over the OEM pipe instead of into it .... if so, you could use the same screws and caulking
Jim
Thanks, the joint would be covered fully with an Eternabond wrap, but yes, it is that very pressure point that I am most concerned about. With rain in the forecast and an upcoming weekend trip, I may go put the initial sewer caps back on at this point and set aside some more time when I'm able to fit the OEM pipe and remove all of the eternabond, dicor, and sewer collar (which I had hoped to initially avoid).
Unless others have tried what I have set up with success, I don't want be the first to find out either way - with my luck a leak.
Thank you.
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 16, 2026
