shades9323's avatar
shades9323
Dealer gave me wrong equal-I-zer size?
So I picked up a 2015 Jayco X23b hybrid today and the dealer installed the equalizer with the 600/6000 head/bars. Loaded trailer weight is 5000 max. I’ve read online people exceeding 600lbs on the tongue. 600lbs is 12%. Am I safe with the 600/6000 or should I go back and ask for the 1000/10000 set up?
  • SoundGuy wrote:
    nohurry wrote:
    IMO, you’re fine. Jayco lists unloaded hitch weight at 365#. It’s a lightweight trailer, and I would bet equal-I-zer over-engineered a bit.
    Disagree. The OP's 2015 X23B offers a mere 1045 lbs CCC even before anything including a battery is added to the trailer. With a GVWR of just 4950 lbs his challenge will be to keep the trailer's GVW, loaded & ready to camp, within that 4950 lb limit. At an average 13% gross tongue weight to gross trailer weight he could easily see this trailer's gross tongue weight average in the 650 lb to 700 lb range. To answer the OP's question - yeah, I'd move up to 1000 lb spring bars but that will require a new head as well.
    I would hope the dealer would switch out the whole system, as they didn’t ask what I wanted. I’ll call them tomorrow.
  • IMO, you’re fine. Jayco lists unloaded hitch weight at 365#. It’s a lightweight trailer, and I would bet equal-I-zer over-engineered a bit. I think your dealer did good. Hook up, and have fun. They’re great hitches.
  • SoundGuy wrote:
    sgip2000 wrote:
    The hitch head is the same for most kits.
    Not for the Equal-i-zer ... if the OP moves up to 1000 lb spring bars he has to change the head as well.
    Do you think I need to move up?
  • The hitch head is the same for most kits. The main differences are the bar size and the ball capacity. If the ball supports a higher weight, you can should be able to just swap bars out, if it is even necessary.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
