- BeatfarmerExplorerI used a decal eraser wheel to remove all of the decals on my TT. Mine were so brittle that i'd get a tiny bit off at a time using a heat gun and scraper. A few inches of decal was taking an hour to remove. With the wheel I removed all of the decals in about 2.5 hours. It also removed the scummy line of old adhesive left around the pealed back decals. Just make sure you use a plug in drill. The constant running pulls down a rechargeable battery fast.
- md_procoupleExplorerWe didn't use any specific vendor yet, but found several good prices on e-bay.
- CarolynandBobExplorerI found a graphic shop here in San Diego. They removed the decals, Cut buffed the whole motor home and made new decals to the same size and the old. I had them change the colors. I also had them make a custom one for the back that has the name of our coach on it. It was spendy but worth it. 10 yr old RV looks new. If I remember correctly it was $1700.00. Forest River wanted $900.00 just for the decals.
- JackfateExplorer3 M makes a spray on decal remover , it lifts & softens ,wrinkles the old decal so you can peel/scrape it off rather easily. Then you need their adhesive remover . You can get these from a good auto parts store that sells paint supply's
- jsmartExplorerWe used a local graphics shop to cover the 'ghosts' on our 2002 class a after using a plastic scraper and some automotive too gone. Covered them with our favorite football team - GO HAWKS.
- cmarkjExplorerIf you want custom decals of almost any size, I would recommend vinyldisorder.com
I had a yellow Winnebago TT and I put a giant hornet on the back wall. I have a few smaller ones inside and out on my current TT. They have a large selection of different stuff, but also will do almost anything custom that you want or design. Very good prices too. - covered_wagonExplorer
Billinwoodland wrote:
I see several vendors for replacement decals on the internet. Anyone have a favorite vendor for this?
My plan is to not use plastic emblems any longer. I'm thinking about lazer cut ss. or aluminum designs and somehow stick them on. - ol_Bombero-JCExplorer
Nice report - but "lacking"!..:(
Give 'em an "atta boy" - it's OK to name the business!
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
