naturist
Sep 18, 2016Nomad II
Pump draws from the onboard tank only. You don't use it when hooked up to shore water source. It is not intended to be a pressure booster for low pressure shore water. If you use it as such, it will attempt to pump water back into the shore water supply, which should lock up the back flow preventer valve required to be in your shore water inlet and you will wind up ONLY using water from the fresh water holding tank. If the back flow preventer does not do its job, you risk contaminating the shore side water system with whatever possibly untreated water is in YOUR fresh water tank, which is why there is required to be such a preventer valve.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
