GlennLever's avatar
GlennLever
Dexter axle Brakes
I have a trailer with dexter axles with 12X2 brakes. (I believe they are 6,200 pound axles???, they are on 10,000 pound registered trailer with upgraded axles)
I just spent 1700 dollars at camping world to replace loaded backing plates and new drums.
The brakes will not hold the trailer in place with the truck in gear at idle. They do not seem to have a clue as to the problem, I never left the dealership, It was pulled back into their shop and they have keep the trailer. I have not heard from them since (they are now closed)
The magnets have been check with an ohm meter, a fully charged auto battery has been connected directly to wire leading directly to the brakes (eliminating brake away switch, brake controller etc)Brakes have been adjusted up and still you can hardly feel the effect of fully applied brakes
I have two vehicles with brake controllers the trailer acts the same on both, I have two other trailers one vintage outlaw and the other a United (the united has dexter axles also) the brakes on those trailers work as they should on both vehicles
HELP
  • Check the wiring along the axles, some wires are routed inside axle and where they come out they can fray and create ground
Looking for advice before your next adventure? Look no further.25,154 PostsLatest Activity: Aug 08, 2025
