Powertour
Apr 13, 2023Explorer II
valhalla360 wrote:
Are you speaking of the 1inch wide strip that squeezes into the metal near the joints?
If yes, you can check by simply running your finger down it. You can feel the screws underneath (or not). If it's relatively new, not a big deal to pull it out and then put it back in. Did that on our latest when I found a couple screws that weren't all the way in.
Yes & understand what you're saying... in certain conditions. The vinyl was so heat pummeled on my rig that it was about rock hard in the majority of places. There were a couple of spots near the roofline trim section that I could see where screws had back out enough to be poking the trim outward. Most of the loose stuff I found however, wasn't backed out near that far. Nonetheless I'm happy I did this job (it needed it).
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
