colliehauler
Feb 04, 2019Explorer III
Thanks Pnichols for pointing that out. If I install it will also go in a sheet metal cabnet covered with Dynamat noise reduction material then have the wood bed frame and mattress for additional noise reduction. I could put in additional sound insulation on the bottom and sides of the bed. You will always have a little vibration which doesn't bother me. The motor and generator are on rubber mounts inside the case.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
