Turtle_n_Peeps
Feb 08, 2017Explorer
nickthehunter wrote:
You can. The only thing that matters is the final drive ratio, which is to say engine rpm to wheel rpm; regardless of rear end ratio or transmission gear ratio. Many people have said with the newer 6, 8 and 10 speed transmissions, the rear end ratio matters NOT.
^^^^^^ on the money!
It goes like this: The more gears you have in the tranny the less gear you need in the rear end. The more power you have in the engine, the less gear you need period.
In the racing game we didn't care what gear that was in the rear end. We would ONLY figure for final drive. Might run the tranny in 2nd gear or 3rd or even 1 to 1 in 4th. It didn't matter as long as the final came out where we wanted it.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
