dodge_guy
Feb 08, 2017Explorer II
A ring and pinion change effectively changes the ratios in the trans. Meaning the truck will work harder with 3.20 gears as opposed to 3.55. this is why manufactures offer different ratios. If all you had to do was just drop a gear then they wouldn't offer the different ratios! Why tow in 4th with a 6speed trans when you can get the proper ratio and tow in 5th or maybe even 6th and get better mileage and towing ability.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
