TenOC's avatar
TenOC
Nomad
Sep 24, 2020
Digi-Pas 2-Axis Smart Cube Level, DWL-90PRO,
If I posted this in the wrong place please move it.
Has anyone use Digi-Pas 2-Axis Smart Cube Level, DWL-90PRO,
How often to calibrate??? I assume that I need to remove it from my 5th wheel pin box when traveling and place it on the pin box when arriving at the campsite.
Your comments are welcome. For $38.00 looks like a good deal.
  • Matt_Colie wrote:
    If you don't need the wireless, there are a number of apps that will give you the same information.
    It took DW a while to figure out why I had my phone on the floor after we parked. I was sitting in the driver's seat setting the level.
    Matt
    We have a 5th wheel so phone on floor will not work.
  • If you don't need the wireless, there are a number of apps that will give you the same information.
    Matt
  • fj12ryder wrote:
    I have one large level on the pin box that I can see from the truck seat to get the trailer level side-to-side,
    I have used one of the large hoppy (?) "marble" levels on the pin box before. This is the default level that I will install if I do not find something better.
  • This is just me, but if you permanently mount two cheap(er) spirit levels on your trailer, then you don't need to move anything around, recalibrate, or mess with any gadget at all.
    I have one large level on the pin box that I can see from the truck seat to get the trailer level side-to-side, and one level mounted on the trailer by the front leg switches for front-to-back. No batteries, no worries about dropping, no messing with anything. Sometimes simple works best.
