YC_1
May 18, 2013Nomad
I'm an ET with 40 yrs of experience and concur. However, just one little caveout. A digital meter can indeed trick you so a handy 12 volt bulb tester as suggested can be very useful and user friendly. Checking fuses will give you a simple go/no go visual. Checking trailer connections won't get you tricked by showing you voltage but when you plug things in it does not work for example.
Not having to look at a meter versus seeing a light is sometimes less painful too. Twisting and turning while making several fuse test under a dash can be difficult.
So I highly recommend you have one of each in your tool box. The test light is about $10.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
