way2roll's avatar
way2roll
Trailblazer
Jan 24, 2023
Dinghy charging from MH
We have a 2011 CRV toad. I have installed separate tail lights that run from the MH 4 pin connector. We have ready brute elite tow bars and so the car's brake lights still activate and after hours of driving and in heavy stop and go, sometimes the battery is very weak when we get to our destination. Aside form pulling a fuse, or a battery disconnect which will reset everything, isn't there a charge wire I can run from the MH to the toad? And if so, how does this work if I am already using the 4 pin connector on the MH for the car's tail lights?
Do I just get a toad charge kit and splice the wires into the existing 4 pin harness? and if so, which wires? I assume the 4 pin harness controls right brake, right signal, left brake, and left signal. If that's the case the current wouldn't be constant would it?
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 08, 2026
