Fifty4F100's avatar
Fifty4F100
Dinghy problems
I have a 2005 PT Cruiser that I have been using for a get-to-work/toad vehicle for about 2 years. Obviously more to work than toad use. For the last little while I've noticed a leak in my power steering system. Most likely just a problem with the PT since it hasn't been the best built car I've owned. But has anybody else had a problem with their power steering after starting to tow their car?
  • Too many variables, hose seal or steering pump case.
    Since not in rack I would get someone to look at replacing the pump and hoses.
    Or at least try to locate the leak.
    maybe try some sealant for power steering.
  • Things are tight under there. I can't really tell. Seems like it is under the pump, but I don't know.
  • If the steering wheel was in the locked position, it could have put excess pressure on the rack and pinion steering system
