mowermech
Jul 28, 2020Explorer II
If you really want to tow it, it IS towable! It is, after all, YOUR vehicle.
However, there is a good chance the output shaft bearing (and possibly other parts) at the rear of the transmission will not be lubricated while towing, and will eventually dry out and seize, destroying the case and shaft.
My personal opinion is that the Owners Manual is the Be-all and End-all when it comes to instructions about how to use the vehicle. Ignore the instructions at your peril.
Good luck.
Good luck.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
