bayoubelle wrote:
I have a question, we are new to dinghy towing and we are currently trying to find a vehicle that has the capability to tow 4 down. We have a few vehicles in mind, but have a question concerning the brake lights on the toad.
One vehicle requires you to pull the DLIS fuse and another says to disconnect a battery cable. I am pretty sure this means the tail lights will no longer work.
Will they work once the vehicle is attached to the tow bar or do we need to add special tail lights?
Also, on a side note, will odometer register when we tow?
I wouldn't choose a toad where I had to do things like that. jeeps are very EZ to hook up. 4WD transfer case to neutral, tranny to park and that's it (for most models). some older models may require a key in the ignition to unlock the steering wheel but the newer models have steering wheels that do not lock. if you look at Jeeps make sure the transfer case has a
manually selectable neutral position and check the owner's manual
before purchasing to be sure it can be flat towed.
all jeeps have extra room in the tail light assemblies for a second bulb to be used in a totally separate wiring harness when towing. that's what we do and it's very simple.
