mhawk4
Apr 27, 2013Explorer
Direc tv antenna
Today i found what i was looking for while on a trip to the land-field. After a few minutes of convincing the attendant, i was able to pull this out of the blue metal box. I already have an ext...
mhawk4 wrote:Randu wrote:
Should work fine if LMB's are good and you watch Standard definition--I've been told it will not work with HD. I have 3, 1 for house, 1 mounted out in yard for trailer use, and 1 in the trailer for traveling. Randu
Thanks for the replies. I am not worry about HD, it is camping and having a TV is a luxury.
Randu; when you are using the antenna in your trailer- how many cables you are running from the antenna and which connector in the LMB are you using?
Dave and Homer thanks for pointing in the right direction.
