Today i found what i was looking for while on a trip to the land-field. After a few minutes of convincing the attendant, i was able to pull this out of the blue metal box. I already have an ext...
The mount is very easy to build and it gives plenty support and stability. All connections are glued in except right under the dish, that joint serves as a pivot to rotate the antenna left or right and the thumb screw holds it in place. If i need to add weight i can add water or sand in the mount. I also used wing nuts on the antenna for easy adjustments.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
