Today i found what i was looking for while on a trip to the land-field. After a few minutes of convincing the attendant, i was able to pull this out of the blue metal box. I already have an ext...
I use to be a directive installer and have installed in many types of rv's
The type of cable required is RG6
If you lnb has 4 connections, what that enables you to do is hook up 4 recievers or 2 dvr's. 2 cables are required to be able to record 2programs at Once but you can use one cable.
Depending on the year of the Rv it sometimes works through the cable connection on the outside without any modifications
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
