mhawk4's avatar
mhawk4
Direc tv antenna
Today i found what i was looking for while on a trip to the land-field. After a few minutes of convincing the attendant, i was able to pull this out of the blue metal box.
I already have an extra satellite box in the attic and plenty of wire.
I am building a base out of pvc pipes unless i come across a tripod, :B just direct me where is a road construction :C
For the questions; need to know if one of you guys is using this antenna or similar and how many cables you are using with it?
Then i guess i will use the outside cable connector to get signal into TT. I imagine connection in the TT is similar to the one in the house.
OK, how do i set the signal for the reception?
I will have more question later, thanks for the help.
Luis
  • Will not work for HD and the dish in the photo is outdated. You will need a slimline 3 or 5 HD dish or similar to receive HD programming.
  • I hope you have active account with DirecTV. I use about 30 feet of line.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Nov 26, 2025
